05-14-2008 10:09 AM - edited 03-15-2019 10:40 AM
Hi All,
I am having an issue with VMO. It was working fine. Then I needed to uninstall and reinstall to create installation documentation.
Now the install is successful, but I do not have the functionality. My vm messages in Outlook 2007 are just little yellow arrows.
I tried uninstalling and reinstalling, cleaning the registry wit no luck.
I also have one user who has 2 computers. both function fine, but one has an icon in the Outlook toolbar and VMO option under the tools menu.and the otherone dos not.
any thoughts?
Randall
05-20-2008 05:56 AM
Please make sure to disable any anti virus, firewall or installation manager application before the installation and testing.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/vmo/release/notes/502vmorn.html
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_tech_note09186a008009453d.shtml
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/compatibility/matrix/cuclientmtx.html#wp43514
06-11-2008 04:14 AM
Hi, how did you uninstall the application?
Use this procedure to properly uninstall the application, then re-install it:
Remove the \Program Files\Viewmail\ directory and all of its components.
Remove all of these files (if they exist) from C:\Winnt\System32:
AvResLoaderSvrSL.dll
AvTrapConnectionHolderSvr.exe
AvTsmSL.dll
Avvox.acm
AvWavSl.dll
AvResSvr.dll
Unpublish the VMO form with this procedure:
From the menu in Microsoft Outlook, choose Tools > Options.
Choose Other.
Click Advanced Options.
Click Custom Forms.
Click Manage Forms.
Make sure the Form Manager window is set to Personal Forms. Choose ViewMail for Outlook, then click Delete.
Click Yes in order to delete the form.
Click Close.
Click OK to all the windows.
Locate the file FRMcache.dat on the client workstation and rename the file to FRMcache.old.
Reinstall the VMO client software.
Please rate this post if successful...
