VMO Issue
Hello, I installed VMO 8 with Unity 7 and CUCM 7 on XP machines. when i try to send a VM to a phone i get :" The Specified Phone Number  does not answer" any idea?
Thanks in advance.
Re: VMO Issue
Do you have TRAP ports for that VM integration?
Are the VM ports able to dial that DN?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Re: VMO Issue
I don't have trap setup and yes the number can dial the VM port number.
Thanks.
Super Bronze
Re: VMO Issue
TRAP = telephony recording and playback; you'll therefore need some trap ports for playback.
Also whether the DN can dial the voicemail port is unrelated to whether the voicemail port can dial the DN; use DNA to verify whether the CSS assigned to the VM ports can dial the end user's DN.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
192
