VMware issue for test lab
I have installed 6.0 on vmware in our test lab, but unable to ping new virtual server IP. Install went without any erros and OS boots up fine.
I setup vmware with bridge networking. During 6.0 install, I defined an ip from the same subnet as physical server, same subnet/default gateway. However after install, I am unable to ping virtual server ip. below are ip settings. Any ideas? Maybe driver issues. If so i'm out of luck as 6.0 doesn't let you get to the OS to modify.
physical server:
192.168.1.10
255.255.255.0
192.168.1.1
virtual server (running 6.0)
192.168.1.30
255.255.255.0
192.168.1.1
thanks in advance,
1 REPLY
Bronze
Re: VMware issue for test lab
Did you try to do it with Different subnets?
220
