Bronze
VMWARE SUPPORT ON CUCM 8.X
Guys,
Ive searched through and contacted my cisco rep but im still not really getting a clear idea on the topic.
i understand the Uc on UCS thing but i really needed to know if Cisco supports the install on VMWARE in an existing customer environment. My rep advised that vmware alone is not supported however UC on UCS is. its a little confusing so im looking for a little clarification.
basically, i have several customers running VM on thier production network and id also like to take advantage of the virtualization on the CUCM side.
can someone clarify in very simple terms
  • IP Telephony
1 ACCEPTED SOLUTION
Re: VMWARE SUPPORT ON CUCM 8.X
You've been informed right, we only support UC on UCS right now and many specific requirements.
Supported HW for virtualization is here:
Supported Servers for Releases of Cisco Unified  Communications Manager, Cisco Intercompany Media Engine and Session  Manager Edition
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
Deploying Unified Communications on Virtualized Servers
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/models.html#wp1128373
Installing Cisco Unified Communications Manager  on Virtualized Servers
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/virtual/servers.html
You need to meet the requirements from the above link for Cisco to support your deployment. Anything else outside those requirements means it's not supported.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
java
java
Bronze
Great thanks for the clarification.
good move forward with UCS but im hoping ill be able to see support for existing VMWARE setups sometime soon.
469
