I would check the IOS image version for your 3825, a bug check shows:
Symptoms: MGCP BRI backhaul calls fail, and debugs for the call failure show the following information:
400 67 Voice call setup failed-Incoming-Outgoing call collision
//-1/xxxxxxxxxxxx/VTSP:():-1:-1:-1/vtsp_call_setup_request:
CALL_ERROR_INFORMATIONAL; Glare Occurred B-Channel=1, Call Id=9
Conditions: This symptom is observed on a Cisco platform that runs Cisco IOS Release 12.4(1) but may also occur in Release 12.3 or Release 12.4T.
Workaround: There is no workaround.
