Voice Conferncing
I have a client who wants to deploy IPT for voice conferencing. He has thre offices (Nigeria, Kenya and ghana). He wants just two IP Phones at each of these sites. He intends to do voice conferencing within these three sites and is very cost conciuos. What is the best solution I can propose for him in terms of devices in these locations. Please help.
Re: Voice Conferncing
Well it will depend on your topology, if you have enough bandwidth between the sites I recommend you to use G.711 between the sites to be able to use a Software Conference Bridge, otherwise you will need DSP resources in order to use a Hardware Conference Bridge.
//Jorge
Thanks for your information. Would a CCM be a better option for this comparet to a CCME?
depends on the amount of users and features you're looking for. if it's a really small deployment a CME would be a good option, maybe a UC500
java
if this helps, please rate
java
www.cisco.com/go/pdi
Am looking at a minimum of two user per site. Would also appreciate if you send a link (URL) to read up documentations od similar soulitions.
all the info is on CCO if you take 5 minutes and search. be proactive.
Cisco Unified Communications 500 Series for Small Business
http://www.cisco.com/en/US/products/ps7293/index.html
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps7293/product_data_sheet0900aecd8061fb06.html
Cisco Unified Communications Manager Express FAQ
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_qanda_item09186a0080875c6f.shtml
java
java
114
