Community Member
Voice flow through ASA after upgrade
Hi everybody thanks for a great forum.
I wasnt sure where to address this, but here goes
I upgraded an ASA 5505 (this is not a firewall question though) from 8.2(5) to 9.1(4). A leap of faith if you know what i mean hehe. Anyway, they have a CME with (in the 8.2 config) 2 nats one TCP and one UDP to 5060 (SIP). Right, it worked fine untill the upgrade ofcourse.
Now finally i got the voice part working, but only by removing one nat (the UDP). I cleared the xlate table and prepared some traces before i tested with a call to a number in there.
And what i saw kind of confused me a bit because the invite comes in over UDP(5060)... Even though i disabled the NAT statement for that?!
This is propably a silly question but how does that work. How can the invite get through to the CME when the NAT is gone? The other funny part is, if i disable the TCP NAT, and enable the UDP NAT it stops working entirely and all i get is a busy tone!
Then when i reenable the TCP NAT (i have to also disable the UDP NAT) i have to wait for a bit before it starts working again.
Hope you guys can shed some light over this.
Cheers everybody
1 REPLY
Can you compare the ASA config before and after upgrade?
Check the presence of "inspect sip" and try to disable the inspection.
Regards.
117
