Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Voice Gateway 3845 - Calling Party number not Showing in ISDN Debug
Hi,Can anyone help with this. I have setup a 3845 voice gateway. Inbound and out bound calls work fine. However on inbound calls the full ddi number does not show only 90. I have run a debug isdn q931 on the gateway and made an inbound call. Callling Party Number does not show - Called Part number does show.
Can anyone tell me is this the provider stopping inbound numbers being presented to the gateway or is there a command I can use to enable this
Dominic
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Voice Gateway 3845 - Calling Party number not Showing in ISD
it's a matter with your provider. They are not sending calling number and you should request that they do.
1 REPLY
176
