Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Voice Gateway – Call connects Ok but dead air in both directions. Need help in interpreting debug output.
Debug voice ccapi inout   is attached.
The numbers as follows:
Originating number:  +86 – 212 – 850 – 7205
Destination Number: +65 – 6215 – 7878
Voice Gateway has E1 controllers 1/0, 1/1, 2/0 and 2/1.
When calls are established via 1/0 or 1/1 the call setup is fine, but dead air in both directions – no voice. But when calls are established cia 2/0 or 2/1 everything works fine and there is no problem. These 4 x E1 lines connect to a PBX. So temporarily 1/0 and 1/1 are shut down as a work-around and all OK. These were all working before and there has been no config or IOS change. So we ssuspect H/W failure.
Slot 1 and 2 of this Cisco 3745 router has High Density Voice Adapter Module P/N 800-03567-01 with E1 (2 Port) Multi-Flex Trunk (Drop&Insert) WAN Daughter Card.
Partial config of the router:
dial-peer voice 9999 voip
application session
destination-pattern .......
voice-class codec 1
session protocol sipv2
session target dns:net.abc.def.com
dtmf-relay rtp-nte
icpif 25
ip qos dscp ef signaling
no vad
dial-peer voice 1 pots
description 8 digits because sip proxy inserts 1
destination-pattern ........
progress_ind alert enable 8
no digit-strip
direct-inward-dial
port 1/0:15
forward-digits 7
dial-peer voice 2 pots
no digit-strip
direct-inward-dial
port 1/1:15
forward-digits 7
dial-peer voice 3 pots
no digit-strip
direct-inward-dial
port 2/0:15
forward-digits 7
dial-peer voice 4 pots
no digit-strip
direct-inward-dial
port 2/1:15
forward-digits 7
Everyone's tags (5)
Re: Voice Gateway – Call connects Ok but dead air in both dire
Forgot to add dial peer voice 999 ( triple 999 )  but 9999 dial pe
er already added.
dial-peer voice 999 voip
description default inbound matching dial-peer
voice-class codec 1
incoming called-number .
dtmf-relay rtp-nte
icpif 25
no vad
The debugs were done when E 1/0 first and then E1/1 were temorarily enabled and calls were established from and to the numbers stated in the previous entry
Hall of Fame Super Gold
Do you have NAT or Firewall devices in path between routers  ?
I am yet to understand the debug voice ccapi inout, but there is the show voice dsp cpmmand done twice as indicated in the attached file. These two successive show voice dsp commands were done during teh dead air connected call.
I notice:
The first time   show voice dsp       showed - partial output without showing all idle DSPs
DSP  DSP             DSPWARE CURR  BOOT                         PAK     TX/RX
TYPE NUM CH CODEC    VERSION STATE STATE   RST AI VOICEPORT TS ABORT  PACK COUNT
C549 001 01 g729r8   4.4.702 busy  idle      0  0 1/0:15    01     0 535950174/46
        2204615
               02 {medium} 4.4.702 IDLE  idle         0 1/0:15    02     0 116573250/11
        8555215
C549 008 01 {medium} 4.4.702 IDLE  idle      0  0 1/0:15    30     0      0/11651
               02 g729r8   4.4.702 busy   idle           0 1/0:15    31    0      0/44115
The second time   show voice dsp       showed - partial output without showing all idle DSPs
C549 001 01 g729r8   4.4.702 busy  idle      0  0 1/0:15    01     0 535954017/46
        2208522
        8555215
               02 g729r8   4.4.702 busy  idle         0 1/0:15    31       0      0/48018
See the RED - counters for TX PACK CNT remain 0.
bevilacqua,
Using E1 controllers 2/0 and 2/1 on the same Cisco 3745 everything works fine. But when using E1 controllers 1/0 and 1/1 causes the problem of dead air in both directions after call sets up successfully.
I don't think this is a NAT FW issue between router and the network if you are thinking of RTP packets being dropped by FW.
Have you tried reloading the router ?
NM-HDV2E160 in Slot 1 ws replaced and the problem got resolved. I am sure if we had just changed the DSP in slot 2 of this card that would have resolved too, but we had pressure from customer to fix in one go.
1358
