Community Member
Voice Gateway: Call Disconnecting
Hi Friends
I have an issue with our voice gateway.
The issue is some of the incomming calls are getting disconnected. Here we are having 12 line fxo. and the gateway is using sip protocol. It is connected to cosmocom server.
Kindly give me a solution for the problem..
Re: Voice Gateway: Call Disconnecting
CME? CUCM? version?
a debug?
does it work for outbound?
sh run?
just saying that calls are disconnected does not provide info for a solution
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
we r not using cme or ccm.
here is a defferent set up we r using cosmocom server. that is implemented by defferent person. it is a call centere application and is using sip
k, anyway we would need a sh run, call flow and debug to tell you what's going on
javalenc
java
Hall of Fame Super Gold
Enable "debug ccsip message" and "debug vpm signal" with "term mon". That should reveal who is disconnecting the call.
Community Member
hi friends
here i m sending the debug
Hi, please enable both debugs for a same call and describe how it got disconnected exactly.
243
