Voice Gateway dial-peers...
Hello Experts,
                     Need your assistance again please.
This is what I am trying to achieve and failing every time..Please assist me.
We have dedicated SIP trunk terminated to CUBE gateway and entire company DID are ported on this SIP trunk and every thing works fine with CUBE,SIP trunks calls and UCM.
Other thing is I have LAB UCS with voice gateway so for my lab testing picked one of the last range of DID on SIP trunk and trying to use them for my test B-ACD...
Issue:
So added VOIP dial-peer on CUBE poiting to my lab UCManager IP for specific range of DID which I picked for my lab but unfortunately nothing is working though.
I did this before,tested and worked fine before moving same DID range to SIP from PRI.
CUBE dial-peers:
dial-peer voice 6000 voip
preference 4
destination-pattern 18038179497 or 1803817949[1-9]
session protocol sipv2
session target ipv4:10.1.31.195
session transport udp
incoming called-number .
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
voice-class sip bind control source-interface GigabitEthernet0/1
voice-class sip bind media source-interface GigabitEthernet0/1
dtmf-relay rtp-nte
no vad
when i call above specific number it hits CUBE router but do not pass to lab router..attached "voice ccapi inout,voice dial-peer and translation debugs..and only voice ccapi.
Please assist me where i am going wrong..I really appreciate you time and assistance.
1 ACCEPTED SOLUTION
Re: Voice Gateway dial-peers...
When you created the SIP Trunk on your LAB CUCM, did you reset the Trunk?
Yosh
HTH Regards, Yosh
Your dial-peer destination is 1803817949 and the called numbers in the debug shows 803817949. You should create a DP with a destination-pattern of 803817949.
Is session target ipv4:10.1.31.195 your LAB CUCM?
Yosh
HTH Regards, Yosh
Can you post a show run of the CUBE?
Yosh
HTH Regards, Yosh
we have translation rule which will replace/add 1 infront of 803 and will make it 1803 though.
Debug log for above rule
Successful substitution; pattern=8038179497 matchPattern=^803 replacePattern=1& replaced pattern=18038179497
Yes targer LAB CUCM is 10.1.31.195
Production CUCM ips are 10.128.163.100,10.128.163.101 and 10.1.32.201
Yosh
HTH Regards, Yosh
I did not do it..let me try though..Thank you.
But I have a another questions for you please...
What is am trying to do is test B-ACD so a call need to hit lab voice gateway to test it or in order to work properly as B-ACS and tcl scrips and config are on voice gateway..so any suggestions and assistance much appreciated.
So your gateway is also a CME router with B-ACD configured?
Yosh
HTH Regards, Yosh
For what it's worth I havent personally played with B-ACD on a CME router. But I find that the link below could be helpful.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/bacd/configuration/guide/40tcl.pdf
Yosh
HTH Regards, Yosh
Yes my lab voice gateway is CME too...thank you so much for sharing link but I have couple of sample guides and documents related to B-ACD...Every thing is configued and ready but not able to test it as I dont have any PSTN line connected or hitting on lab voice gateway so planed to use DID for my testing and working on it...
Did calls start hitting your lab CUCM, after resetting the SIP Trunk?
Yosh
HTH Regards, Yosh
works like a champ....thank you so much..!
Any suggestions regarding my other questions please.
337
