Community Member
Voice Gateway - DSP Testing
Hi All,
We have faced the issue in the PVDM Module . During the peak time router is getting reloaded because of the DSP crash
We want to test the DSP in our lab & want to simulate issue. How we can simulate high traffic in to DSP resources ?
Thanks in Advance...
Purple
Hi ,
you can run the command on production router to check dsp status .
show voice dsp group all.
State should be UP else Fail .
regds,
aman
You can try to reset your DSP modules using below command:
test dsp device all reset
Also, please share the output of show tech...
Do you get any messages or error regarding DSP crash or failure ? Also if you see any crash dump in router, please share those as well..
-Piyush
712
