Voice Gateway failover issue....
Hi, we have 2 VGW. each gateway contains 3 PRI links. RG & RL has been configured properly and associated with route pattern in the call amanger.
what I want is, IF ALL VGW1 LINKS ARE BUSY CALL WILL ROUTED TO VGW2 (OR) VGW1 ANG VGW1 LINKS FAILED THEN ONLY CALLS WILL WILL BE ROUTED TO VG2.
BECAUSE OUR REQUIREMENT IS IF ALL THE LINKS IN VGW1 ARE BUSY CALLS HAS TO BE REDIRECTED TO VGW2. BUT ONE OF OUR COLINGUE IS TELLING VG1 OR ALL VGW1 LINKS FAILED THEN ONLY IT WILL ROUTE TO VGW2.
RG ABD RL HAS BEEN CONFIGURED PROPERLY.
Re: Voice Gateway failover issue....
I would say test it yourself but IMO it will pick up next gateway in your RG when all ports will busy on first one.
Why? Same decision CM take to use next free port. No more ports to use on this gateway then check if we have another gw configured.
rate if this help
Correct Call Manger should take care of the routing to to the other gateway if the first one is full. For back you should be able to add a dial-peer with a lower priority to route the calls over to the other gateway.
Hi bas, thanks for your update. we are using 2 H.323 gateway integrated with with call managers.
considering with the above will it redirect to another gateway if all the links are busy or manually we need to create a voip dial peer with lower priority which points to another gateway?
121
