Voice gateway for branch.
I have cme in the main site. I need a cheap voice gateway (router) with 4 fxo ports for the branch.. Which model can I use?.
The wan connection is dedicated 1024kbps.
Thanks.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Any of the 29XX ISR G2 will do just fine. 2901 for example would be a cheap candidate.
Chris
The ip phones in the branch must register with cme at the branch. the fxo are for local calls.
the 2900 is an expensive solution.
I would like to know, if a router 800 with a voice gw image will work?.
310
