Community Member
voice gateway forward digit query
Hi, have recently built two identical 3725 voice gateways that talk MGCP to call manager 5.1,
however, on incoming calls, one forwards 4 digits to call manager & the other forwards 6 digits.
any suggestions why this is the case & how I can alter it to just 4 digits?
I planned to have 4 digit internal extensions, however, on the phones that you can call direct on, these need to be 6 digit from one gateway.
1 REPLY
Green
Re: voice gateway forward digit query
Check significant digits at Voice port level in CCM Admin (Device|Gateway|Select the Gateway (T1, FXO,etc) and check that parameter) other option could be that your Telco is forwarding different number of digits...
Otherwise you may play with Translatio Patterns:
For example:
You recieve: 124000
Your internal dial plan will be 5XXX
You can create a Translation Pattern.
to be 124XXX and change under called party transform mask to 5XXX and you will be done...
115
