Voice gateway ISDN error messages
I have following messages appear on my voice gateway
Dec 21 09:35:43.513: ISDN Se0/0/1:15 SERROR: process_pri_simple: NO name in GTD
*Dec 21 09:35:43.533: ISDN Se0/0/1:15 SERROR: process_pri_simple: NO name in GTD
*Dec 21 09:35:48.053: ISDN Se0/0/1:15 SERROR: process_pri_simple: NO name in GTD
*Dec 21 09:35:48.065: ISDN Se0/0/1:15 SERROR: process_pri_simple: NO name in GTD
Cisco IOS Software, 3800 Software (C3845-SPSERVICESK9-M), Version 12.4(24)T4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 03-Sep-10 10:00 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
MOFA_VG03 uptime is 26 weeks, 4 days, 14 hours, 49 minutes
System returned to ROM by reload at 19:28:47 UTC Fri Jun 17 2011
System image file is "flash:c3845-spservicesk9-mz.124-24.T4.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3845 (revision 1.0) with 226304K/35840K bytes of memory.
Processor board ID FHK1350F01Z
2 Gigabit Ethernet interfaces
62 Serial interfaces
4 Channelized/Clear E1/PRI ports
32 Voice FXO interfaces
16 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
and some call getting disconnected
show version is
export@cisco.com.
1 REPLY
Hall of Fame Super Gold
Cosmetic error, for which yoiu can update IOS.
379
