02-23-2012 12:40 AM - edited 03-16-2019 09:44 AM
I had a wiard problem with customer's new 3925 ISR with 15.1(2) .T4 IOS that has 3 T1 CAS circuits and telco has provisioned to send the last 4 digits however, gateway recoginzed only 1 digit (the first digit of the last 4 digits) and had telco removed their translation and outpulse all 10 digits and it worked fine. Is there any bug related to this issue or what am I missing here?
02-23-2012 08:11 AM
If you run a debug what do you see??? 1 digit?? 4 digits?? 10 digits??
What you get in the setup message is completely up to Telco, if they're sending you wrong info, that's something you need to discuss with them.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
02-23-2012 02:59 PM
Seeing only 1 digit. and how can i attach a file...?
02-23-2012 05:41 PM
If you're only seeing 1 digit in the setup message from telco, that's something they need to fix.
java
02-23-2012 05:43 PM
understood but can't explain why it is working fine with their pbx though....
