Voice gateway pri and dsp
Hello, is there a command on cisco 2800 voice gateway to see how many pri's there is also what is the relationship between pri and dsp. Like how many dsp are there in one pri? Thanks,
Green
Haracio, show isdn statusshow
Haracio,
show isdn status
show voice dsp
Hope this helps
Alex
Regards, Alex. Please rate useful posts.
VIP Purple
Hi,  You also use the
You also use the commands
show voice dsp detailed
show voice dsp group all
show isdn service
regds,
aman
Hello,So I do show inventory
So I do show inventory on voice gateway and it says I it has one pvdm2-32 and two pvdm2-64 which adds up to a total of 160 dsp to use.  However i do show voice dsp group all and it shows 12 dsp each one with 16/16 max singnal/voice channel which is a total of 192 dsp. How many dsp do I really have 192 or 160 to use and another question if i divide 192 by 24 channels its  8 PRI's correct or I'm calcualting the wrong way to get the number of PRI's?
VIP Purple
Hi, PVDM2-32 has 2DSPs while
PVDM2-32 has 2DSPs while PVDM2-64 has 4 DSPs . In your case, it would be total 10 DSPs.
you can also refer the doc by AOK.
https://supportforums.cisco.com/document/123126/cisco-pvdm2-and-pvdm3-dsp-creditmips-allocation
regds,
aman
76
