Voice gateway PRI channels
Hello, Does anyone know which command on a voice gateway will make it use all 24 channels on the controller without having channel D for signaling?
VIP Purple
Hi, I doubt whether this is
I doubt whether this is possible since D channel is used for call control and signalling purpose .
regds,
aman
I dont think that is possible
I dont think that is possible,
what problem are you trying to solve?
Please remember to rate useful posts, by clicking on the stars below.
Hi,In case you have multiple
In case you have multiple PRI's you can use NFAS which allows to control multiple PRI's with a single d-channel
http://www.cisco.com/c/en/us/support/docs/dial-access/integrated-services-digital-networks-isdn-channel-associated-signaling-cas/9584-quadt1-nfas.html
Manish
69
