12-18-2009 06:35 AM - edited 03-15-2019 08:50 PM
I am going to migrate a remote office's old PBX system to our centralized CCM with Callmanager V5.12. My questions is the office has a PRI with 16 channels. Do I set up the voice PRI on the gateway the same way as if it has 24 channels?
controller T1 0/3/0
framing esf
linecode b8zs
cablelength long 0db
pri-group timeslots 1-24 service mgcp
if not, should I change the pri-group command to 17 channels(including the D Channels)?
pri-group timeslots 1-17 service mgcp
Thanks in advance
Mark
Solved! Go to Solution.
12-18-2009 06:57 AM
Yes, but drop the service MGCP.
We do NOT support fractional PRIs with MGCP, if you want to use it you'll need H323
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
12-18-2009 06:57 AM
java
