Community Member
voice gateway PRI
can I use a VWIC2-1MFT-T1/E1 to connect to a Telco PRI? My 3845 is showing a Service-Engine1/0 but not T1 controller.
1 ACCEPTED SOLUTION
Re: voice gateway PRI
Sure you can. Since its a t1/e1 card, it can be configured as a t1 or e1 card. You need to use the card type command from global configuration mode and configure the controller as a t1 or e1. Once this is done, you will see the controller interface show up in running config. Note that if you cofnigure the port as a t1/e1 once, to change from t1 to e1 or vice versa, requires a reboot.
Sankar
PS: please remember to rate posts!
Sankar
Community Member
This might be off subject but do you plan on running mgcp on your router and link it up with your Call Manager?
Community Member
yes
144
