Voice gateway problem Call not receive debug isdn q931 output
Hello , I have a  problem with cisco 2921  voice gateway (PRI) Could you please someone explain me about someting.
Debug and and Dial peers output is below,
Thanks Advance
Jun  1 17:59:16.839: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x17FF
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98392
                Exclusive, Channel 18
        Progress Ind i = 0x8283 - Origination address is non-ISDN
        Calling Party Number i = 0x2181, '05551112223'
                Plan:ISDN, Type:National
        Called Party Number i = 0xC1, '6727498'
                Plan:ISDN, Type:Subscriber(local)
        Sending Complete
Jun  1 17:59:16.847: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x97                                        FF
Tadim_VG02#
Jun  1 17:59:16.847: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x9                                        7FF
        Cause i = 0x809B - Destination out of order
Jun  1 17:59:16.983: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x17FF
Jun  1 17:59:17.007: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0
Jun  1 18:01:05.467: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0003
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA98381
        Progress Ind i = 0x8083 - Origination address is non-ISDN
        Calling Party Number i = 0x2181, '2626727380'
        Called Party Number i = 0xC1, '03444131834'
Jun  1 18:01:05.587: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8003
Tadim_VG02#
Jun  1 18:01:07.087: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x8003
        Progress Ind i = 0x8482 - Destination address is non-ISDN
Tadim_VG02#
Jun  1 18:01:11.735: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x8003
Jun  1 18:01:11.739: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x0003
Tadim_VG02#
Jun  1 18:01:16.687: ISDN Se0/0/0:15 Q931: RX <- FACILITY pd = 8  callref = 0x8003
        Facility i = 0x91A112020170020122300AA1053003020101820100
                Protocol Profile = Remote Operations Protocol
                0xA112020170020122300AA1053003020101820100
                Component = Invoke component
                        Invoke Id = 112
                        Operation = AOCDChargingUnit
Tadim_VG02#
Jun  1 18:01:36.071: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x0003
        Cause i = 0x8090 - Normal call clearing
Jun  1 18:01:36.387: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x8003
        Facility i = 0x91A11102017502012430093007A1053003020101
                0xA11102017502012430093007A1053003020101
                        Invoke Id = 117
                        Operation = AOCECharging Unit
Jun  1 18:01:36.407: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0003
DİAL PEERS
dial-peer voice 120 voip
incoming called-number .T
codec g711ulaw
dial-peer voice 130 pots
destination-pattern 05.........
port 0/0/0:15
prefix 05
dial-peer voice 20 pots
destination-pattern 9[2-9]......
port 0/0/0:15
forward-digits 7
dial-peer voice 21 pots
destination-pattern 90[2-4].........
port 0/0/0:15
forward-digits 11
dial-peer voice 22 pots
destination-pattern 905.........
port 0/0/0:15
forward-digits 11
dial-peer voice 23 pots
destination-pattern 900T
port 0/0/0:15
forward-digits all
1 REPLY
The first call to 6727498 doesn't match any dial peers and fails.
The second call matches dial peer 130.
What specific info are you looking for?
2046
