Voice Gateway Redundancy
I have a 3845 Voice gateway with 2 PRIs.... but i dont have the gateway level resundancy
can somebody help me with the design on gateway level redundancy???
how do I have 2 gateways with gateway and PRI redundancy??
appreciate if anybody can help me with LLD as well..
1 REPLY
Silver
Re: Voice Gateway Redundancy
Follow Cisco's Gateway/Route Group/Route List construct:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/3_1_2/ccmcfg/b03rtlst.html
I assume that you also have two network modules for each of the PRI's (i.e VWIC-2MFT-E1/T1). When you create your gateway you place each PRI into a Route Group in order of preference and this is where you acheive your gateway redundancy. If one PRI is busy or n/a calls will route via the second PRI.
With regards to your LLD, what help do you require? Please email me at dezoconnor@yahoo.co.uk with your requirements and I'm sure we can sort something out!
1342
