Community Member
Voice gateway Router configuration
Hi all,
Anyone knows the configuration of Router for outgoing & incoming calls to PSTN.
Sudeesh
Silver
Re: Voice gateway Router configuration
Yes. Many people on this forum do! :)
You need to post some more details. What router? IOS? CallManager? MGCP? PBX? PSTN?
Cheers,
Tim
there is also a search option when you log into Cisco.com i just looked MGCP configuration and found this among several other good links:
MGCP IOS Gateway (San Jose) Interactive Voice Network Configuration Example
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00807f8b61.shtml
i can tell you for sure that there are plenty of examples if you try looking
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
132
