Voice Gateway with FXO and FXS
I have a scenario where CUCM-A is connected to voice gateway-1 installed with FXO card and these FXO cards are connected to FXS card on voice gateway-2 which is connected to CUCM-B.
I have 3 below queries please answer.
An IP phone which is registered to CUCM-A can call to an IP phone which is registered on CUCM-B or I need to have a FXS card on VG-1 which will connecting to FXO card on VG-2
An ip phone which is registered to CUCM-B can call to CUCM-A IP phone
I want calling to and from both the CUCM A/B ip phones
  • IP Telephony
1 REPLY
Green
Hi, 1) CUCM-A (FXO) ---> CUCM
1) CUCM-A (FXO) ---> CUCM-B (FXS) Will call the dialled number in B
2) CUCM-B (FXS) ---> CUCM-A (FXO) You will need to use PLAR on the FXO and
choose an ip phone or hunt pilot for all incoming calls on A
If you want both ways to be the same you will
need to use ISDN BRi/PRI or E&M signalling which of course will
need different cards in your gateways.
You could also use IP as SIP or H323 trunks then you dont need the gateways at all.
Hope this helps
Alex
Regards, Alex. Please rate useful posts.
43
