VOICE GATEWAYS AND PRIS
Hi to all
We have two gateways with one pri in each gateway.The two gateways are in two different locations and the first gateway is the main and the second is the backup
our questions are:
1) if you know the isp can recognise (with d channel) if the pri is down?
2) how the cucm (is connected with gw via h323) can recognize that the first pri is down (the gw is up but the pri is down) and then send the calls (outside calls) to the second Gateway
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
Please find my Answers in-line below..
Ans : Yes. ISP would stop sending calls over that line/trunk untill they receive proper acknowledgement signalling from the gateway router's PRI D channel. Callers would hear busy tone.
Ans : This can be achieved using proper config of Route List >> Route Group >> Add gateways with priorities defined. So that, if the preferred gateway is down ( for whatever reason ), CUCM looks for next gateway as defined by priority.
HTH ?
Please rate helpful posts.
GP.
Hi and thank you for the reply
for the second point we have created a route group that we have assigned first the main GW and second the backup GW with Distribution Algorithm "top down"
I think is the same that you mentioned before..BUT i believe that the CUCM can change and route the calls (outgoing calls) to the backup GW if the GW is down and not if the pri is down ...
Do you have any guide  for that?
Yes, you are right if the gateway is H.323 ( I just forgot to notice that you already mentioned as H.323 gateway, sorry about that ). My above statement holds true for MGCP gateways.
My thought about achieving it with H.323 gateway would be to have a VOIP dialpeer on main gateway pointing to second gateway in case the PRI fails on main gateway.
Call flow would be CUCM >> Main H.323 Gateway >>  it finds the PRI to be down >> Call follows the dial-peer pointing towards second H.323 gateway >> Second gateway routes it to PSTN.
GP.
Green
You will have to add the following line of text to the H323 gateways.
no dial-peer outbound status-check pots
This will ensure that a no circuit/channel available message - cause code 34
is sent back to CUCM so that it can step on the next GW in the route group.
Please see
https://www.cisco.com/en/US/docs/ios/12_3t/voice/command/reference/vrht_d1_ps5207_TSD_Products_Command_Reference_Chapter.html#wp1459139
Alex
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Hi to alex , thank you for the update
could you pls alex and gajanan confirm that the below config is correct?
MAIN CUCM:10.1.1.1
MAIN GW:10.1.1.6
BACKUP GW:10.1.1.7
EXTENSIONS ARE: 1XXX
On the main GW
dial-peer voice 100 voip
description **TO THE MAIN CUCM**
translation-profile outgoing ADD9
preference 1
destination-pattern ....
session target ipv4:10.1.1.1
voice-class codec 2
voice-class h323 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 300 voip
description **TO SECOND GW**
preference 2
incoming called-number ....
session target ipv4:10.1.1.7
voice-class codec 2
voice-class h323 1
no vad
ON THE SECOND GW
preference 1
voice-class codec 2
voice-class h323 1
no vad
description **TO THE MAIN GW**
preference 2
session target ipv4:10.1.1.6
voice-class codec 2
voice-class h323 1
no vad
Green
I take it you have added the POTS dial peers for the outgoing calls
Alex
Re: VOICE GATEWAYS AND PRIS
If you mean the dial peer pots for the pstn network yes i have added these pots
i forgot also something
the main GW has two pris and the second GW one pri
So far are you believe that the config is correct between GW to GW?
Is anything change now that we have two pris to the main GW?
dial-peer voice 1 pots
description **CYTA FIRST Pri **
destination-pattern 9T
progress_ind alert enable 8
direct-inward-dial
port 0/0/0:15
dial-peer voice 2 pots
description **CYTA SECOND Pri **
preference 10
direct-inward-dial
port 0/0/1:15
description **FIRST Pri **
direct-inward-dial
port 0/0/0:15
description **SECOND Pri **
preference 10
direct-inward-dial
port 0/0/1:15
Green
Yes these look OK.
Remember if your router has more than 1 IP address to bind 1 of them as the H323 source
Could be
int loop 1
ip add 10.10.10.10 255.255.255.255
h323-gateway voip bind srcaddr 10.10.10.10
Alex
thanks alex
the command no dial-peer outbound status-check pots is for mgcp gateway and not h323 right?
Green
No it is for H323 & SIP gateways
Alex
Thank you guys for the answers
Let me to test it and before give you the correct answer in case that its not working to give you un update for your records
Otherwise i will back here to confirm that everything its ok
Thank you again
439
