voice hunt-group and Miss call
Abdullah Hashim
Hello every one,
we Have CME 8.6 Problem is when we  received call in this number 200 (Hunt Group) all Phone are ring ok but after the frist phone 90 Pickup or take the call , all other Phone like 91,92,93,94 display a Miss call in our Pohnes
with this config
voice hunt-group 1 parallel
list 90,91,92,93,94
timeout 45
pilot 200
telephony-service
video
no auto-reg-ephone
max-ephones 25
max-dn 50
ip source-address 172.16.0.1 port 2000
timeouts interdigit 2
system message YAZ
url services http://172.16.0.2/voiceview/common/login.do
url authentication http://172.16.0.2/voiceview/authentication/authenticate.do
cnf-file location flash:
cnf-file perphone
user-locale U1 load CME-locale-de_DE-German-8.8.2.3.tar
network-locale U1
load 7941 SCCP41.9-2-1S.loads
load 7941GE SCCP41.9-2-1S.loads
load 7942 SCCP42.9-2-1S.loads
load 7945 SCCP45.9-2-1S.loads
load 7961 SCCP41.9-2-1S.loads
load 7962 SCCP42.9-2-1S.loads
load 7965 SCCP45.9-2-1S.loads
load 7970 SCCP70.9-2-1S.loads
load 7971 SCCP70.9-2-1S.loads
load 7975 SCCP75.9-2-1S.loads
load ata ATA030204SCCP090202A.zup
time-zone 20
time-format 24
date-format dd-mm-yy
voicemail 98
max-conferences 8 gain -6
moh "flash:/music-on-hold.au"
multicast moh 239.10.16.16 port 2000
web admin system name admin secret 5 $1$0P8E$Vd4UlXt/5E7ieljS4BJur0
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
transfer-pattern 0
secondary-dialtone 0
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template  1
network-locale 1
user-locale 1
ephone-dn  1  dual-line
number 90 secondary 70290
pickup-group 1
label Zentrale
name Zentrale
call-forward all 200
call-forward busy 98
call-forward noan 98 timeout 25
huntstop channel
hold-alert 30 originator
ephone-dn  2  dual-line
number 91 secondary 70291
pickup-group 1
huntstop channel
ephone-dn  3  dual-line
number 92 secondary70292
pickup-group 1
huntstop channel
ephone-dn  4  dual-line
number 93 secondary 70293
pickup-group 1
huntstop channel
ephone-dn  5  dual-line
number 94 secondary 70294
pickup-group 1
label MANAG
name MANAG
huntstop channel
ephone-dn  6  dual-line
number 95 secondary 70295
pickup-group 1
label MANAG2
name MANAG2
huntstop channel
ephone-dn  10
number 80..
mwi on
ephone-dn  11
number 81..
mwi off
ephone  1
mac-address A418.758B.XXXX
ephone-template 1
type 7975
button  1:3
ephone  2
mac-address 58BF.EA21.XXXX
ephone-template 1
type 7975
button  1:2
ephone  3
mac-address 3CCE.7359.XXXX
ephone-template 1
type 7942
button  1:1
ephone  4
mac-address 3CCE.73AC.XXXX
ephone-template 1
type 7942
button  1:4
ephone  5
mac-address 0022.905C.XXXXx
max-calls-per-button 2
type ata
button  1:5
ephone  6
mac-address 2290.5C46.XXXXX
type ata
button  1:6
thank you for help
Ayodeji Okanlawon
This is expected behaviour. Once a call is presented to a phone and not answered it is registered as missed call. The only way to avoid this is to use a shared line.
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
thank youaokanlawon
for you snswer but I said the frist number will answer I mean the voice hunr group have this numbers 90.91.92.93.94
we recive a call and phone 90 will take the call that mean he answer the call but all other number in the same group showing our display Miss call
thank again
I understand that but you are using parallel algorithm which means all the other numbers also ring and only one answers the call, so the others will show as a missed call. This is a normal behaviour.
