Voice Hunt Group in SRST (call-manager-fallback)
I'm looking for assistance in getting my Voice Hunt Group pilot accessible from the PSTN when the router is in SRST mode (call-manager-fallback)
Under normal conditions, the hunt pilot of 9555 5000 is routed to CUCM which controls the hunting process.
In SRST mode, I wish for the same hunt  pilot/group to be active.
If I set the hunt pilot on the SRST router to the full number (9555 5000), this bypasses CUCM under normal conditions
If I set the hunt pilot on the SRST router to the extension (5000), 5000 is not recognised when external calls arrive in from the PSTN.
i.e. The hunt pilot does not create additional dialpeers using "dialplan-pattern 1 955550.. extension-length 4 extension-pattern 50.." command
I have tried creating additional dialpeer using "destination-pattern 95555000" with a preference 0 to CUCM, hoping the hunt pilot dialpeer would have lower preference, however the hunt pilot dialpeer created from the hunt pilot commands takes preference.
I have also tried "alias 1 95555000 to 5000" under call-manager-fallback. This does not seem to work either
When in SRST mode, the hunt pilot works either way when you call the corresponding number from an internal phone.
Am I missing come configuration?
Subset of the  SRST router configuration:
voice hunt-group 1 parallel
list 88401,88402,88403
timeout 60
pilot 5000
secondary-dialtone 0
max-conferences 8 gain -6
transfer-system full-consult
limit-dn 7940 2
limit-dn 7942 2
timeouts interdigit 3
ip source-address 10.10.10.1 port 2000
max-ephones 30
max-dn 60
system message primary SRST mode: Network Down
voicemail 0296661000
translation-profile incoming toPSTN
translation-profile outgoing toPhone
call-forward busy 00296661000
call-forward noan 00296661000 timeout 15
time-zone 42
date-format dd-mm-yy
dial-peer voice 1 pots
description --Inbound POTS Dialpeer--
incoming called-number 955550..
direct-inward-dial
port 0/0/0
dial-peer voice 100 voip
description --Dialpeer to CUCM1--
preference 1
destination-pattern .T
modem passthrough nse codec g711alaw
session target ipv4:10.20.20.10
voice-class codec 1
fax-relay ecm disable
fax rate disable
no vad
Any help would be much appreciated.
1 ACCEPTED SOLUTION
The behaviour is as expected, because in SRST, by default,the dial-peer hunting
choices are - Longest match > explicit preference > least recent use.
Use "dial-peer hunt 2"
"dial-peer hunt 2" forces the dial-peer hunting choices to be - Explicit preference >
longest match in phone number > random selection.
Hence, since the dial-peers  have preference 0  respectively, the call
will hit them first.
Hope this helps!
Karthik Sivaram
Hope this helps!
Karthik Sivaram
Thanks Karthik, the "dial-peer hunt 2" command was helpful.
I also set "preference 2" under the voice hunt group.
This allowed the dial-peers for the Hunt Pilot to CUCM to take preference, and fall back to the SRST router in the event of WAN failure.
2497
