Voice Hunt Pilot - Calling Number Display (SRST)
Under normal conditions, calls arrive from the PSTN via the H323 gateway to CUCM.
CUCM uses Calling Number Transformation patterns on the gateway device pool to transform the calling number into E164 format
e.g. 296662600 gets translated to +61296662600
When calling a Cisco IP Phone in SRST mode, the calling numbers are translated using the "translation-profile outgoing toPhone"
When calling the hunt pilot number 95555000 when the router is in SRST mode (call-manager-fallback),
The calling number displayed on the hunt group member phone is "296662600  From: +61296662600"
The calling history (Missed, Received calls etc) of that phone shows the pre-translated number e.g. 296662600
The "Details" of the Missed/Received call shows the post-translation of "+61296662600"
Is there a away to show E164 format numbers/post-translated numbers for the Missed/Received calls to the hunt group members, while keeping the calling number presented to CUCM the under normal conditions the same??
The dialpeer created for the hunt pilot is dialpeer 2147483647. However, I could not find a way to modify it.
voice translation-rule 2
rule 1 /\([23478]........\)/ /+61\1/ type national national
rule 2 /([2-9].......\)/ /+618\1/ type subscriber subscriber
rule 3 /\(.*\)/ /+\1/ type international international
voice translation-profile toPhone
translate calling 2
voice hunt-group 1 parallel
list 88401,88402,88403
timeout 60
preference 2
pilot 95555000
secondary-dialtone 0
max-conferences 8 gain -6
transfer-system full-consult
limit-dn 7940 2
limit-dn 7942 2
timeouts interdigit 3
ip source-address 10.10.10.1 port 2000
max-ephones 30
max-dn 60
system message primary SRST mode: Network Down
dialplan-pattern 1 955550.. extension-length 4 extension-pattern 50..
voicemail 0296661000
translation-profile incoming toPSTN
call-forward busy 00296661000
call-forward noan 00296661000 timeout 15
time-zone 42
date-format dd-mm-yy
dial-peer voice 1 pots
description --Inbound POTS Dialpeer--
incoming called-number 955550..
direct-inward-dial
port 0/0/0
dial-peer voice 5000 voip
description --Hunt Group Primary--
destination-pattern 95555000
session target ipv4:10.20.20.1
voice-class codec 1
fax-relay ecm disable
fax rate disable
no vad
dial-peer voice 5001 voip
preference 1
session target ipv4:10.20.20.2
voice-class codec 1
fax rate disable
no vad
  • IP Telephony
463
