VIP Super Bronze
Voice Interface on serial1/0:15 Status Shows reset
I am having a very weird problem on E1-pri card on NM-1CE1T1-PRI module.
After I configured the pri-group timeslots 1-31,16...I noticed the associated voice-port 1/0:15 was not created. Interface serial 1/0:15 was created.
When I do a sh ip int br...The ints1/0:15 status shows reset....
as shown below:
Serial1/0:0 unassigned YES unset reset down
Serial1/0:1 unassigned YES unset reset down
Serial1/0:2 unassigned YES unset reset down
Serial1/0:3 unassigned YES unset reset down
Serial1/0:4 unassigned YES unset reset down
Serial1/0:5 unassigned YES unset reset down
Serial1/0:6 unassigned YES unset reset down
Serial1/0:7 unassigned YES unset reset down
Serial1/0:15 unassigned YES unset reset down
My config looks like this...
card type e1 1
network-clock-participate slot 1
isdn switch-type primary-net5
Controller e1 1/0
interface Serial1/0:15
encapsulation hdlc
no ip address
isdn incoming-voice voice
no cdp enable
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Voice Interface on serial1/0:15 Status Shows reset
NM-1CE1T1-PRI does not support voice.
VIP Super Bronze
Thank you!!!!!!!!
You're welcome. Thanks for the nice rating and good luck!
656
