voice mail auto forwarded to general greeting
i have CUC Ver. 8.6  and when i forward user to his voicemail i hear system general greeting not user voicemail ,
any one have idea about this problem please help .
VIP Super Bronze
what happens when you press the message button on the user phone, do you hear the user greeting?
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Are you sending the digits CUC is expecting??
Also check the direct or forwarding call rules, someone might have changed something there.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Re: voice mail auto forwarded to general greeting
Hi.
Make also sure that user has been imported in cuc db with his right extension.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hall of Fame Super Silver
In addition to all great posts above check the following:
  • VM Profile Mask to ensure sufficient digits are masked
  • Ensure "use external phone number mask" is not checked on either a Hunt Pilot pointing to UCON if using SCCP integration or Route Pattern if using SIP.
  • If using SIP ensure "outbound diversion header" is set
HTH,
Chris
235
