Voice mail greetings
is there a way to disable users from recording voicemail greeting?
I am using Cisco Unity Connection version: 2.0.1.2000-337
We don't want users to be able to personalize greetings. we only want users to use system default greetings only.
mwuest
Hello
I have the same Problem, do you have a Solution for this problem?
not yet. the problem is that though you can disable the alternate greetings, the users can still activate them as the conversation give them the option. this is a worrying factor because the conversations which comes with Unity connection can't be changed or modified.
Is there any expert who can help us here? i think the solution can be there if the setup options on conversations can be disabled.
