Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
voice mail issue
Dear All,
I have 2 branches running on voip. Both sides i have implemented CME.Locally voice mail if wokring fine. but between branches voice mail doesnt picks the call.
Can anybody help me in this regard.
I will be very thankful.
Thanks & Regards,
Malik
1 ACCEPTED SOLUTION
Bronze
Re: voice mail issue
Malik,
Sounds like a codec issue. Is the VM at the central site and the branches access the VM via the WAN. If so you may be using the G729 codec across links but I am pretty sure the VM uses G711. You may have to look at this as well as you Call Admission control, In the end you may need to implement transcoders at the branch sites
Hopes this helps
Paul
Bronze
Malik,
Hopes this helps
Paul
Dear Mr. Paul,
I really appreciate for your help and support.
I have implemented transcoders at both my sites. But still voice mail is not working. I have attached the running configuration of routers of both the sities. Can you please have a look at the configuration and let me know if i am doing any mistake.
Your consideration in this regard will highly be commendable.
Waiting for your reply.
Thanks & Regards,
Malik.
Malik,
I am by far no expert, but here is how I setup my last customer like this:
CME/UE Site A (aka CME-A/UE-A) is connected to CME/UE Site B (aka CME-B/UE-B) via a IP WAN.
When a user on CME-A wants to place a standard phone call to CME-B, I have a dial peer voip to address that (you have that). If user no CME-B wants to call user on CME-A I have a dial-peer voip for that (you have that too).
So calls work find between sites. You have a dial-peer voip for users on CME-A wanting to call UE-A that addresses target, codec, dtmf, and vad. So Site-A can call UE-A. You have the same on Site B.
What I did is to setup dial-peers between Site-A users calling UE-B. This dial peer would address target, codec, dtmf, and vad just like your other Site-A to UE-A dial peer.
NOTE: These go directly to the UE at each site (aka - target), not (hopped) via the CME.
You have on cme-dmm-3825:
dial-peer voice 1001 voip
description **** Unity Express Voice Mail***
destination-pattern 4000
session protocol sipv2
session target ipv4:192.168.0.252
dtmf-relay sip-notify
codec g711ulaw
no vad
Add:
dial-peer voice 331 voip
description **** Unity Express VM, Site-B***
destination-pattern 331
session target ipv4:192.168.6.2
codec g711ulaw
no vad
Then add a dial-peer on muc-ryd:
dial-peer voice 4000 voip
description **** Unity Express VM, Site-A***
codec g711ulaw
no vad
NOTE: I would modify my "destination-pattern" to also pickup the auto-attendant too or add a seperate dial-peer.
Hi buddy,
Thanks for your reply...i will configure it and will let you know..thanks again,
Malik
165
