Voice Mail ports in CM need resetting . . .
On a recent installation (Unity 4.2(1) and CM 4.2(3)) I've started noticing a peculiar issue whereby VM ports on CM stop working properly and need to be reset. There are 96 ports and the failing vm ports seem to happen in succession (in other words, it begins at the first one and goes one on by one until all of the ports run out.) At that point, the ports need to be reset whereby they start acting fine again. Has anyone run into this kind of issue?
-Shikamaru
Re: Voice Mail ports in CM need resetting . . .
What TSP version are you using ?
8.1(3)
-Shikamaru
I think the latest version is 8.2. It might be a good idea to upgrade the TSP version. It may solve your problem.
107
