Voice mail problem
hi All,
I have configured voice mail on cisco 7960 with CUE 2.2.but when when call comes to phone, in case of not answering the call is forwarded to voice mail box.
what will be the possible reason?
Thanks in advance.
Re: Voice mail problem
hi All,
I have configured voice mail on cisco 7960 with CUE 2.2.but when when call comes to phone, in case of not answering and busy call, the call is NOT forwarded to voice mail box.
Thanks in advance.
Hall of Fame Super Silver
Do you have "voicemail" statement under telephony-service in CCME pointing to VM pilot?
Is the VM pilot configured on CUE?
Do you have call-forward busy, and call-forward noans x timeout x under ephone-dn?
Do you have transfer-pattern statement under telephony-service?
What failure do you get? Fast busy, etc?
Can you posts your CME config (I am assuming you're using CME not CM, let us know otherwise)
Chris
Hi Chris,
Thanks a lot for ur reply.The problem has been solved.I am using CME in integration with CUE.The problem is with dialer-pattern statement in telephony services.i removed the statement now the incoming call is forwarded to voicemail box in case of noan/busy.My call forward busy/noan statement was correct.
As i am new to VOICE/ IP Telephony can u just brief me that why it was not working with the dialer-pattern statement.
attached is the config.Now when i press the Message button on ip phone its take too much time to got to voice mail box..pls guide.
thanks in advance.
It is due to a bug as the CUE did not recognize the expended number, as a workaround you can use a translation rule applied to the dial-peer pointing to CUE. Such as:
voice translation-rule 1
rule 1 /^212555\(3...\)/ /\1/
voice translation-profile CUE
translate called 1
translate calling 1
translate redirect-called 1
dial-peer voice 100 voip
translation-profile outgoing CUE
destination-pattern 3000
dial-peer voice 101 voip
destination-pattern 2125553000
the above example assumes that your DID range is 212-555-3... and the VM pilot is 3000.
HTH, please rate all posts!
Chris
294
