Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Voice Mail time restriction
How can I change the settings for vm ? For example after 5PM all calls between extensions goes directly to the voice mail. Is that possible to create a profile for speciific extension like vm goes after 6PM and rest after 5PM.
Please advice. Thank You.
1 REPLY
I created a new scheduled
I created a new scheduled under user vm profile. problem solved. Thanks
15
