Voice Mail TIme
It appears that after the changing of the
DST my voicemail is still one hour behind. I'm using
a CME on a 2800 series router. Any ideas on what the re
quired change should be?
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Voice Mail TIme
Hi Rudy,
Yes, any CUE version 2.3(4) or greater will solve this issue
Cheers!
Rob
Re: Voice Mail TIme
In the CUE GUI, go to System > Network Time & Time Zone Settings and make sure the time zone and NTP reference are correct.
Brandon
Re: Voice Mail TIme
I've confirmed that the settings are correct. It's only when you retrieve the VM dis the date behind 1 hour..??
Re: Voice Mail TIme
Is CUE pointing to CME for NTP? Is the time correct on the CME?
Brandon
Re: Voice Mail TIme
Yes, the CUE is pointing to th IP of the CME and the time is correct in the displa
y of the CME.
Re: Voice Mail TIme
Can you post the following?
From CUE CLI:
show clock
From CME CLE:
show clock
"clock timezone" and "clock summer-time" commands
ntp commands
Brandon
Re: Voice Mail TIme
Brandon--I see that the CME show clock is the 1 hour
behind..?? Would that be from the missing upgrade Rob was referring?
Re: Voice Mail TIme
Yes it would. Good call, Rob!
Brandon
Re: Voice Mail TIme
Hi Rudy,
Just to add one note to the good tips from my friend Brandon (+5 "B")
What version of CUE are you running?
Field Notice: FN - 62682 - U.S. Daylight Saving Time (DST) Policy Changes Effective March 2007 - for All Cisco Unity Express (CUE) Releases Prior to 2.3.4
If Cisco Unity Express is not upgraded to CUE 2.3.4 with the new U.S. DST policy changes, timestamps will exhibit a one hour time clock offset lasting three weeks beginning at 2 A.M. on the second Sunday in March of 2007. They will also exhibit a one hour time clock offset lasting one week beginning at 2 A.M. on the first Sunday in November.
http://www.cisco.com/en/US/ts/fn/620/fn62682.html
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
Re: Voice Mail TIme
Hi Rob, I'm currently running the Cisco Unity Express Version 2.3
...this is probabaly my issue..??
from the link you've provided I can download an upgrade I presume that will correct the problem?
Re: Voice Mail TIme
Hi Rudy,
Cheers!
Rob
Re: Voice Mail TIme
Thanks to both you and Brandon for your support!!!!
223
