Voice Media Gateway configuration on mgcp
Hi All
I have configured E1 in the voice Media Gw on AS5400XM using ss7 on pri-group
and also the E1 using mgcp protocol,i can able to do both the configuration on the same MGW
but the links are fluctuating while trying to activate.
Could any one tell me whether SS7 pri-group and mgcp configuration is possible
on the same Media Gateway ?
Dinesh
1 ACCEPTED SOLUTION
Re: Voice Media Gateway configuration on mgcp
You can configure the mgcp-pri group only when you are functioning your PGW in callcontrol Mode. I have
tested the similar configuration using ss7 and mgcp on the same mgw but only one protocol works on one mgw
either ss7- Q.931 or Mgcp.
The PGW2200 can only work in signalling mode -or- in call control  mode. So MGW configured to this PGW works either using Q.931  ie ss7 pri-group configuration or Mgcp using ds0-group.
But not in both mode situation.
Lavanya
Lavanya
Hi Lavanya,
        Thanks.
V Dinesh Kumar
164
