tka
Community Member
Voice Name PLAY/RECORD field in th eUnity Connection Edit User Basics
what is the purpose of the Voice Name PLAY/RECORD field in th eUnity Connection Edit User Basics ?
Any help plz
regards,
Re: Voice Name PLAY/RECORD field in th eUnity Connection Edit Us
that's the recorded voice, to put it simply it's your name recorded by you
the one you get when you check your VMs if you enabled unity to greet you with your name or when you leave a VM to other user so they hear your name and not the DN
if you want to use dial by name it's also mandatory to define it.
java
if this helps, please rate
java
www.cisco.com/go/pdi
tka
Community Member
Sorry but when we say dial by name, is it based on voice recognition ? If yes , which is the level of efficiency and for what languages ?
thanks.
124
