Voice over IP - VPN problem
Hello all, i have the following scenario :
My problem is :
1. I have IP communicator on the 10.20.50.0 network that i want to register with a VPN tunnel. I create a tunnel to the ASA5505 and when i try to ping the
10.20.100.0 network, there is no problem, but when i try to reach the other two - 10.10.100.0 and 192.168.100.0 i can't. There is a trunk between the 3945 and the netgear switch. Do you have any ideas what should i do to connect to the 10.10.100.0 network? Thanks
Everyone's tags (4)
1 ACCEPTED SOLUTION
Hi Svetoslav.
Can you please post your ASA config to help you to modify it accordingly?
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
any ideas friends?
Hi Svetoslav.
When you are connected with vpn client, which are secured routes that you receive from ASA.
Let me know
Carlo
Sorry friend , i don't get it where can i check it ?
Re: Voice over IP - VPN problem
Hi.
I was asking for secured network received by you client once you are connected.
If you are using anyconnect you can see it through statistics window and secured route tab.
Carlo
hello friend, i'm using cisco vpn client and in secure routes i see only 10.20.100.0
Hi.
That's why you cannot reach other networks.
Please contact your security administrator and ask him to modify your profile to allow you to reach all other subnets.
Carlo
Thank you for the answer, but i should allow the profile to connect to the netrorks... I allow all inside networks but it only gets access to 10.20.100.0
Hi Svetoslav.
Carlo
251
