Community Member
voice-port 0/0/1no caller-id enable
now i dont' reveived and send call's from CCM and cisco 3825
The status of BRI is ok
ISDN BRI0/0/0 interface
dsl 0, interface ISDN Switchtype = basic-net3
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 65, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
but when a show ccm-manager , at the end you can see:
MGCP Domain Name: MUTILVACISCO3825.grupopanasa.com
Priority Status Host
Primary Registered CALLMANAGER01 (192.30.3.246)
First Backup None
Second Backup None
Current active Call Manager: 192.30.3.246
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 12:07:15 PCTime Nov 17 2007 (elapsed time: 00:00:03)
Last MGCP traffic time: 12:07:15 PCTime Nov 17 2007 (elapsed time: 00:00:03)
Last failover time: None
Last switchback time: None
Switchback mode: Graceful
MGCP Fallback mode: Not Selected
Last MGCP Fallback start time: None
Last MGCP Fallback end time: None
MGCP Download Tones: Disabled
--More-- Backhaul Link info:
Link Protocol: TCP
Remote Port Number: 2428
Remote IP Address: 192.30.3.246
Current Link State: OPEN
Statistics:
Packets recvd: 2989
Recv failures: 0
Packets xmitted: 2726
Xmit failures: 0
BRI Ports being backhauled:
Slot 0, VIC 0, port 1
Slot 0, VIC 0, port 0
Configuration Auto-Download Information
Current version-id: {84423BF3-AFC0-4A37-A9C7-781EA4C959F5}
Last config-downloaded:00:00:00
Current state: Waiting for commands
Configuration Download statistics:
Download Attempted : 18
Download Successful : 16
Download Failed : 0
Configuration Attempted : 10
--More-- Configuration Successful : 10
Configuration Failed(Parsing): 0
Configuration Failed(config) : 0
Last config download command: Reset
Configuration Error History:
voice-port 0/0/0no caller-id enable
voice-port 0/1/1no caller-id enable
voice-port 0/1/0no caller-id enable
this voice-port no caller-id is ok??
this is my problme??
help please.
Alfonso
Silver
Re: voice-port 0/0/1no caller-id enable
Try this BUG - CSCsc00795
Hall of Fame Super Gold
Hi, CSCsc00795 is ¨"CCM MGCPbrid device didn't handle CcSelectFacilityReq message properly" so it doesn't seem aplicable.
Why is that you some often point at unrelated bugs for any kind of issue?
ISDN lines support caller-id by default, and you do not appear to have the option to disable it on the voice-port.
This is not specifically a problem, caller-id is an analogue service which when enabled on FXS ports transmit Caller ID, while FXO ports receive Caller ID.
Allan.
289
