You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Voice-Port and Voip Phone same Ephone-dn?
Hi Everyone,  Have a CME running version 15.1.
One of the voice-ports (specifically, voice-port 2/0/10) on the router acting as number 1832.  The users want this number to also ring on two other phones, both of which are IP based (7911 and 7921).  Can you tell me if this is possible?  Adding the ephone-dn to the two IP phones makes the voice-port not ring...
So am looking for a way to make it work on all of these phones... any suggestions?
Thanks in advance,
Ken
  • IP Telephony
Everyone's tags (3)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
For new versions, you may need to do  "license accept eula end-user" and reload.
Hall of Fame Super Silver
Will that work with a voice port in the mix though?  The voice port appears to be the deciding factor...
You best option is to configure the FXS port in SCCP mode.
Thaat till allow you you to configure an share line across all the desired destinations.
Ken,
It sounds like you need to implement either a parallel hunt group or a shared line/overlay dn on each IP Phone. FXS ports will not natively work with hunt groups, you will need to convert it to be able to act like an IP endpoint using SCCP. This is done by configuring a feature called STCAPP. Info can be found at the below link:
https://supportforums.cisco.com/docs/DOC-9443
HTH,
Nic.
So I looked into this Nic... I have some concerns... with VG224's and other FXS ports in use... will this disrupt any of them to make this change?
I can try it, but want to be sure this doesn't mess anything else up.
Hi Ken,
Your best bet is probably to wait till after business hours as standard before altering config. Have a copy saved so if anything goes wrong you have a "restore to default" backup you can redeploy in a few minutes if needed. It has been a while since I have done a config on STCAPP, but from memory it should overlay right ontop of the current config, maybe with a shut/no-shut command if necessary on the port. It basically just changes the port directly from analog to IP capable.
Nic.
Hmm...
Ok am trying to figure out how to do this effectively, and by the way, I'm no CME genius.
So I reconfigure the Dial-peer:
dial-peer voice 210 pots
description Sunfield Warehouse
service stcapp
port 2/0/10
forward-digits 0
Which appears to work ok, but how do I then direct the proper phone number to it?  I can't do a destination pattern, and I don't see where I can assign the number properly, am I to do a hunt group with multiple phones, this being one somehow?  I guess I'm not getting how to make this work overall...
Ken,
You will need to create a dummy ephone and ephone-dn for the config, as you are effectively turning the port into an IP phone, it will need to have an "IP Phone" assosciated with it.
ephone-dn 21
number 1000
description STCAPP dial
ephone 10
device-security-mode-none
mac-address XX.XX.XX.XX
type anl
button 1:21
note to find your analog mac address you can do a "sh stcapp device summary" on the router, which will bring up all ports configured with STCAPP and their mac address.
HTH,
Nic.
Alright everyone... I went through this and here is what happened.
I successfully converted the voice port to an stcapp port, no problem... assigned the number and called it with no difficulty.
voice-port 2/0/10
station-id name Sunfield Warehouse
caller-id enable
port 2/0/10
forward-digits 0
ephone-dn 99
number 1826
exit
ephone 99
mac-address FBD6.BFAD.040A
type anl
button 1:99
So this worked fine.  Yet... next step was to make this number ring on both this ephone and two IP ephones.
I next added:
ephone  39
description Warehouse
mac-address XXXX.XXXX.XXXX
ephone-template 10
max-calls-per-button 4
busy-trigger-per-button 2
type 7921
button  1:99
ephone  17
mac-address YYYY.YYYY.YYYY
ephone-template 10
type 7911
button  1:99
At this time, it rings on the IP phones but not on the analog.  The analog is now gone and non-functional.  Yet, as soon as I remove the button commands from the two IP ephones, the analog works immediately.
So I tried a parallel hunt group, thinking by making the two IP phones one phone number, and the analog another, then hunting between them, we would be good... YET... this also disables the analog line.
So is there a way to make this all work together?
1326
