voice port configuration
Below is the partial configuration.
My Query is when 3/0/0 and 3/0/1 ports are busy with local calls (calls starting with non zero numbers), then the local calls should be established on 2/1/x which are configured for calls starting with '0'. This configuration is not working, needs modification. Pls help in this
dial-peer voice 210 pots
preference 8
destination-pattern 0[1-4,6-9][0-9]?
no digit-strip
direct-inward-dial
port 2/1/0
dial-peer voice 211 pots
preference 8
destination-pattern 00[1-4,6-9][0-9]?
no digit-strip
port 2/1/1
dial-peer voice 300 pots
preference 8
destination-pattern [1-4,6-9][0-9]?
no digit-strip
port 3/0/0
dial-peer voice 301 pots
preference 8
no digit-strip
port 3/0/1
preference 8
no digit-strip
direct-inward-dial
port 2/1/0
preference 8
no digit-strip
port 2/1/1
preference 8
no digit-strip
port 3/0/0
preference 8
no digit-strip
port 3/0/1
preference 8
no digit-strip
direct-inward-dial
port 2/1/0
preference 8
no digit-strip
port 2/1/1
preference 8
no digit-strip
port 3/0/0
preference 8
no digit-strip
port 3/0/1
Re: voice port configuration
Play with preference command, if you give low preference value the call will routed via that port, higher the preference value at port for back-up route.
Hall of Fame Super Gold
You should use trunkgroups (configure under voice-port and in place of port unde DP). That way you will:
- have single DP eliminating redundant configuration
- be able to use multiple trunk-group for a same DP, if desired.
- define precedence for individual lines with trunk-group
- define an hunt-scheme on how to use the lines
- pull statistics on trunkgroup usage and it's individual lines.
204
