Community Member
voice port showing OFF-HOOK even after disconnect call
We have UC520 with 4 FXO & two analog line, My scenario is when anybody calls on 08 9377 3097 (voice-port0/1/1) means All incoming call which are coming  on 08 9377 3097 (voice-port0/1/1) should be diverted to 206 (ext.). If anybody are unable to receive call on 206 within 15 sec. then call should be divert to my  Mobile from 08 9377 0540 (voice-port0/1/0)
After disconnecting Incoming call means Hang up the phone & make call again on same no. Voice-port 0/1/1 that time I found  08 93773097 (Voice-port 0/1/1 ) is still engaged(busy) & also saw voice port is going to OFF-HOOK.
I have use belo configuration
voice-port 0/1/0
supervisory disconnect dualtone mid-call
output attenuation -6
cptone BR
timeouts call-disconnect 5
timeouts wait-release 5
timing sup-disconnect 1000
connection plar opx 202
caller-id alerting dsp-pre-allocate
voice-port 0/1/1
cptone BR
connection plar opx 206
Is there anyone who can point me in the right direction
Everyone's tags (1)
343
