Community Member
Voice Ports and PSTN Switch
I have 2 voice ports connecting 2 pstn lines. I have call-forward configured for an ephone. When a call from PSTN triggers the call forward, the call goes out to PSTN on the second PSTN line to a cell phone.
The problem is: The 2 ports are always off-hook when the call is forwarded. It seems the ports cannot detect if the call is over or not.
To make matters worse, when I reloaded the router to restore the ports to off-hook status, the Telecom side is still on-hook because a voice message(voice mail service for POTS line)is heard when a call is made from PSTN; a busy signal is heard when a call is made from inside IP phone.
My voice-port configuration is as follows:
voice-port 0/2/0
no battery-reversal
connection plar opx 300
caller-id enable
voice-port 0/2/1
no battery-reversal
caller-id enable
Is there a configuration on the ports to solve this problem?
1 REPLY
Re: Voice Ports and PSTN Switch
This may provide the answer you're looking for:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml
Michael.
138
