Community Member
Voice PRI-GROUP Test??
Hello All,
I have 2x 2621 routers that are configured back to back using a T1 crossover cable (VWICS). I just need to know if my config is right and how do I test the channels to see if they go active for a going call. The config it below. Thanks.
Router 1
controller T1 1/0
  linecode b8zs
  framing esf
  clock source line
  (User Side)
  pri-group timeslot 1-12
int s1/0:23
                isdn incoming-voice voice
        isdn protocol-emulate user
Router 2
controller T1 1/0
  linecode b8zs
  framing esf
  clock source internal
  (Switching Side)
int s1/0:23
        isdn protocol-emulate network
Re: Voice PRI-GROUP Test??
You can use SJphone with direct H.323 option or can configure IOS based CallManager Express and register Cisco IP communicator as many as you want.
Muhammad Amir Raza
To see if channels are going active for a call use debug isdn q931.  Even if you're doing a back-to-back configuration between routers you should still see the call setup and teardown.
Cool Loreena, I'm glad I could help!
Don't forget to mark your issue as "resolved" and rate any helpful posts
307
