Voice PRI problem
I have a h323 gateway (a 3825 router) that is having inbound calling problems I haven't been able to figure out.
When calling to the system, users are getting busy signals.
show ip int brie shows
Serial0/0/0:0              unassigned      YES unset  down                  down
Serial0/0/0:1              unassigned      YES unset  down                  down
Serial0/0/0:2              unassigned      YES unset  down                  down
Serial0/0/0:3              unassigned      YES unset  down                  down
Serial0/0/0:4              unassigned      YES unset  down                  down
Serial0/0/0:5              unassigned      YES unset  down                  down
Serial0/0/0:6              unassigned      YES unset  down                  down
Serial0/0/0:7              unassigned      YES unset  down                  down
Serial0/0/0:8              unassigned      YES unset  down                  down
Serial0/0/0:9              unassigned      YES unset  down                  down
Serial0/0/0:10             unassigned      YES unset  down                  down
Serial0/0/0:11             unassigned      YES unset  down                  down
Serial0/0/0:12             unassigned      YES unset  down                  down
Serial0/0/0:13             unassigned      YES unset  down                  down
Serial0/0/0:14             unassigned      YES unset  down                  down
Serial0/0/0:15             unassigned      YES unset  down                  down
Serial0/0/0:16             unassigned      YES unset  down                  down
Serial0/0/0:17             unassigned      YES unset  down                  down
Serial0/0/0:18             unassigned      YES unset  down                  down
Serial0/0/0:19             unassigned      YES unset  down                  down
Serial0/0/0:20             unassigned      YES unset  down                  down
Serial0/0/0:21             unassigned      YES unset  down                  down
Serial0/0/0:22             unassigned      YES unset  down                  down
Serial0/0/0:23             unassigned      YES NVRAM  up                    up
If I do a show isdn stat I get
Global ISDN Switchtype = primary-ni
ISDN Serial0/0/0:23 interface
dsl 0, interface ISDN Switchtype = primary-ni
    Layer 1 Status:
ACTIVE
    Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x807FFFFF
    Number of L2 Discards = 0, L2 Session ID = 227
    Total Allocated ISDN CCBs = 0
When doing debug isdn q921 & 931 I get
Dec 29 04:59:20.097: ISDN Se0/0/0:23 Q921: User RX <- SABMEp sapi=0 tei=0
Dec 29 04:59:20.097: ISDN Se0/0/0:23 Q921: User TX -> UAf sapi=0 tei=0rm mo
And I see this when someone attempts an outbound call (which seems to work, although I see errors here)
Dec 29 01:46:48.055: ISDN Se0/0/0:23 Q921: User TX -> INFOp sapi=0 tei=0, ns=0 nr=0
Dec 29 01:46:48.055: ISDN Se0/0/0:23 Q931: SETUP pd = 8  callref = 0x0080
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Facility i = 0x9F8B0100A11A02010202010080124F68696F20436F6D707574657220526F6F6D
Protocol Profile =  Networking Extensions
0xA11A02010202010080124F68696F20436F6D707574657220526F6F6D
Component = Invoke component
Invoke Id = 2
Operation = CallingName
Name Presentation Allowed Extended
Name = Ohio Computer Room
Calling Party Number i = 0x2181, '9373259254'
Plan:ISDN, Type:National
Called Party Number i = 0x80, '19378645356'
Plan:Unknown, Type:Unknown
Dec 29 01:46:49.055: ISDN Se0/0/0:23 Q921: L2_EstablishDataLink: sending SABME
Dec 29 01:46:49.055: ISDN Se0/0/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Dec 29 01:46:50.055: ISDN Se0/0/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Dec 29 01:46:51.055: ISDN Se0/0/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Dec 29 01:46:52.055: ISDN Se0/0/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Dec 28 20:46:53.055 est: %ISDN-6-LAYER2DOWN: Layer 2 for Interface Se0/0/0:23, TEI 0 changed to down
Dec 29 01:46:53.055: ISDN Se0/0/0:23 **ERROR**: CCPCC_CallOrigination: SETUP timed-out (2nd T303) to NETWORK.  The SETUP failed.
My provider says that they are not seeing anything from the D channel
I have powered off the router and reseated the T1 card, but it didn't help.
Any advice here would be great, because I'm not sure where or what the issue is
1 ACCEPTED SOLUTION
Voice PRI problem
Please
debug isdn q931
debug isdn q921
And then "ter mon" if you're connected by vty line.
After these commands try make test call and put output here please.
Also,  "sh isdn timers"
There is some config mismatch with your Provider i think.
Voice PRI problem
Please
debug isdn q931
debug isdn q921
Voice PRI problem
People are able to dial out through this gateway, but I only get busy signals when trying to dial in through it.
When dialing out, here is the output for debug isdn q931
Dec 29 13:58:03.969: ISDN Se0/0/0:23 Q931: SETUP pd = 8  callref = 0x0080
Standard = CCITT
Facility i = 0x9F8B0100A11A02011902010080124F68696F20436F6D707574657220526F6F6D
0xA11A02011902010080124F68696F20436F6D707574657220526F6F6D
Invoke Id = 25
Calling Party Number i = 0x2181, 'XXXXXXXXXX'
Called Party Number i = 0x80, 'XXXXXXXXXX'
Dec 29 13:58:04.968: ISDN Se0/0/0:23 Q921: L2_EstablishDataLink: sending SABME
Dec 29 13:58:04.968: ISDN Se0/0/0:23 Q921: User TX -> SABMEp sapi=0 tei=0
Dec 29 13:58:04.968: ISDN Se0/0/0:23 **ERROR**: CCPCC_CallOrigination: SETUP timed-out (2nd T303) to NETWORK.  The SETUP failed.
show isdn timers
SPR-c3825-RTR-MDF-01#sho isdn timers
    ISDN Serial0/0/0:23 Timers (dsl 0) Switchtype = primary-ni
ISDN Layer 2 values
K     =   7 outstanding I-frames
N200  =   3 max number of retransmits
T200  =   1.000 seconds
T202  =   2.000 seconds
T203  =  30.000 seconds
ISDN Layer 3 values
T301  = 300.000 seconds
T303  =   4.000 seconds
T304  =  20.000 seconds
T305  =  30.000 seconds
T306  =  60.000 seconds
T307  = 180.000 seconds
T308  =   4.000 seconds
T309    Disabled
T310  =  30.000 seconds
T313  =   4.000 seconds
T316  =  30.000 seconds
T318  =   4.000 seconds
T319  =   4.000 seconds
T322  =   4.000 seconds
T323  = 120.000 seconds
T3OOS =   5.000 seconds
TGUARD=   8.000 seconds, Expiry = REJECT_CALL
*** dsl 1 is not configured
*** dsl 2 is not configured
*** dsl 3 is not configured
*** dsl 4 is not configured
*** dsl 5 is not configured
*** dsl 6 is not configured
*** dsl 7 is not configured
*** dsl 8 is not configured
*** dsl 9 is not configured
*** dsl 10 is not configured
*** dsl 11 is not configured
*** dsl 12 is not configured
*** dsl 13 is not configured
*** dsl 14 is not configured
*** dsl 15 is not configured
*** dsl 16 is not configured
*** dsl 17 is not configured
*** dsl 18 is not configured
*** dsl 19 is not configured
*** dsl 20 is not configured
*** dsl 21 is not configured
*** dsl 22 is not configured
*** dsl 23 is not configured
*** dsl 24 is not configured
*** dsl 25 is not configured
*** dsl 26 is not configured
*** dsl 27 is not configured
*** dsl 28 is not configured
*** dsl 29 is not configured
*** dsl 30 is not configured
*** dsl 31 is not configured
*** dsl 32 is not configured
*** dsl 33 is not configured
*** dsl 34 is not configured
*** dsl 35 is not configured
*** dsl 36 is not configured
*** dsl 37 is not configured
*** dsl 38 is not configured
        *** dsl 39 is not configured
*** dsl 40 is not configured
*** dsl 41 is not configured
*** dsl 42 is not configured
*** dsl 43 is not configured
*** dsl 44 is not configured
*** dsl 45 is not configured
*** dsl 46 is not configured
*** dsl 47 is not configured
The telco insists that the isdn switch type is primary-ni
Voice PRI problem
Ask your TELCO Provider to check it's channels (1-10) settings.
It seems They've blocked incoming calls to your side.
I've faced with that kind of mistake,but outgoing only in my case.
Re: Voice PRI problem
Are you sure that isdn switch type is realy primary-ni?
Voice PRI problem
Telco is not sending anything back to you, a setup ACK or a CALL_PROCEED, and the SETUP message is timing out after 4 seconds.
Other than making sure the T1 card is OK, I'd call the telco to find out why they're not replying to the setup message you're sending.
Show them that SETUP you're sending and ask them if they're sure the config and link they're looking at from their side is correct.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Voice PRI problem
Yup I agree with Java,
Ask telco to verify their configs
1345
