Community Member
VOICE QUALITY If using CIPC from outside to dial PSTN
Hi All,
Voice quality is not good if placing call from Internet using CIPC with vpn tunel and going to PSTN, but its good as long as it is directed within network.
1 ACCEPTED SOLUTION
Silver
Re: VOICE QUALITY If using CIPC from outside to dial PSTN
If you are using Cisco IP Communicator over a remote connection (for example, on a VPN connection from home or a hotel), voice
quality might suffer from insufficient bandwidth. Enabling the ?Optimize for low bandwidth? feature when you are using Cisco IP Communicator over a remote connection can prevent robotic-sounding audio and other problems. To enable this feature, right-click on the Cisco IP Communicator interface and choose Preferences > Audio. You might choose to apply audio filters to enhance voice quality when using low bandwidth.
Silver
Community Member
chked Optmz 4 lwbadwdth, but still the quality is choppy..
further help appreciated
Hall of Fame Super Gold
You need to control at least some element in the whole scenario to apply a minimum of QoS. eg, the routers connecting to the internet, etc.
Once you have this, you can describe the details, to see what can be done.
Community Member
hi, this is my internet router acl....
access-list 107 permit tcp any any eq www log
access-list 107 permit tcp any any eq 8080
access-list 107 permit udp any any eq domain log
access-list 107 permit tcp any any eq domain
access-list 107 permit tcp any any eq smtp log
access-list 107 permit esp any any log
access-list 107 permit ahp any any log
access-list 107 permit udp any any eq isakmp
access-list 107 deny ip any any log
access-list 108 permit tcp any any established log
access-list 108 permit esp any any log
access-list 108 permit ahp any any log
access-list 108 permit udp any any eq isakmp
access-list 108 deny ip any any log
Please lookinto it
These access list do not control QoS. To answer you question you need to include a diagram for the phone connection end-to-end, indicating which make and model are all the routers / Fws switches , etc that are under your control.
Community Member
may be some udp (rtp) is blocked
No, if you have blocked ports you hear no voice, while this is a quality issue. As I said you need to include a diagram explaining your topology. A very simple ascii one will do.
Community Member
also below is cfg 4 my pstn gateway dspfarm,,
dspfarm transcoder maximum sessions 4
dspfarm rtp timeout 60
dspfarm codec g729 vad disable
dspfarm connection interval 60
dspfarm
Silver
Past experience of problems like this is that the playout buffers on the IP handsets is larger than the default playout buffer on the voice ports of the gateway routers. As a result, calls between IP handsets are fine since they can accomodate the extra delay across the network, but the router voice ports cannot hold the audio segments long enough to wait for delayed packets.
Try the following - depending on the type of voice card you have, configure the 'playout-delay nominal' setting to a higher value (250-500msec) to allow the voice port to wait a longer period for incoming traffic across the IP cloud.
251
