Bronze
Voice Recognition Tab Missing 7.0.2
Guys,
im looking high and low for the voice recognition tab in system administration >system>configuration and im not seeing it. Version is 7.0.2 UM with Exchange
does 7 have this under some other option or is it a bug ?
thanks
1 ACCEPTED SOLUTION
Community Member
Re: Voice Recognition Tab Missing 7.0.2
I have also Unity 7, Build Number  7.0(2)
but I can see the Voice Recognition from the administration page directly under system, no need to go for configuration.
Could you please check under system licensing >> featured If you have license for Voice recognition
Good luck
Community Member
Good luck
Bronze
Man,
do you have to be correct all the time?.....hehehe its embarrassing i know. thats the first thing i should have checked and i just didnt. youre correct, not licenses for VR.
BTW, this was CUWL. should it have been included or is this still required to be purchased separately?
Community Member
I do not think it is coming with CUWL, but I am not sure,
Bronze
thanks yeah i dont think it comes with it.
thanks though.
you have been rated
148
