Voice Register Pool - Pool Tag too large, maximum 0
Hi All,
i am currently trying to configure SRST to work with about 10 9971s. my SCCP phones works fine in SRST, but not the SIP. i am using the following guide to configure
http://www.cisco.com/en/US/docs/voice_ip_comm/cusrst/admin/sccp_sip_srst/configuration/guide/srst_setting_up_using_sip.html#wp1012426
but, when i try entering the following command
Router(config)# voice register pool 12
i keep getting "Pool too large, maximum 0"
i tried entering a whole bunch of number, but none worked. does anyone know how i can get pass this?
thanks.
Surendra
Can you please post the complete "sh run" and "sh version"?
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
I'm running into the same problem. Have you found a way to solve this?
Greets,
David
Hi David,
i did get a solution, try the following:
voice service voip
ip address trusted list
  ipv4 172.XX.0.0 255.255.0.0
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip refer
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
  call start interwork
sip
  session transport tcp
  registrar server expires max 600 min 60
voice register global
system message Service Interruption
max-dn 10
max-pool 8
id network 172.xx.xx.xx mask 255.255.255.0          >> network for voice
voice register pool  2
sip-ua
retry notify 6
retry options 1
timers notify 100
registrar ipv4:172.xx.xx.xx expires 3600    >>> this is the CUCM IP
hope it helps for you too..
Hi Surendra,
What the manual is missing is a step:
max-dn "number"
max-pool "number"
So if you define max-pool, then you are able to configure the register pool.
Overview of steps to make SIP SRST operational:
1. On CUCM configure SRST SIP reference
2. Update voice service on VGW:
voice service voip
sip
  registrar server
3. General voice register commands:
max-dn 20
max-pool 8
4. Voice register pool commands:
id network 10.199.112.0 mask 255.255.255.0   => network range of SIP IP Phones
preference 1
proxy 10.199.112.88   => IP Address of VGW
voice codec 1
Now I got my SIP IP Phones registered on VGW :-)
Thanks for helping me! :-)
Greets,
David
Thanks david.. Happy to help
6082
